Do I need to earth a metal pendant lampshade?
samd
by samd » Fri Aug 14, 2009 8:05 pm
Hi - apologies if this is a silly question - I've looked in the project pages and on other threads.
I've replaced a ceiling rose (successfully I think - it works anyway) with a metal finish rose with a clip-on hook Google "wickes.co.uk/6-A-Plug-in-Ceiling-Rose/invt/156368"
I want to hang a metal lampshade from it - currently I have two core unearthed flex and a plastic lampholder. Is that ok (the ceiling rose is earthed) or do I also need 2 core + earth flex and a metal lampholder with an earth?
Any help greatly appreciated!
Sam
by sparx » Sat Aug 15, 2009 1:36 pm
Hi I would say if metal shade is fitted to plastic lamp holder it does not need earthing, regards Sparx
samd
by samd » Sat Aug 15, 2009 1:38 pm
Hi - thanks for the reply. Just to check - the shade won't be hanging from the lampholder itself - it's hanging off the hook on the ceiling rose on a metal chain. Is that still ok?
moggy1968
by moggy1968 » Sat Aug 15, 2009 9:36 pm
looking at the piccie I would say it almost certainly should be earthed. check the instructions, they should tell you.
chris_on_tour2002
by chris_on_tour2002 » Mon Aug 17, 2009 2:40 pm
yes it's fine - the metal shade will be hanging from a metal chain attached to the metal hook of the ceiling rose, which you say is earthed (certainly should be). so the shade will be earthed. the lampholder needs no earth as it's plastic and double insulated.
It is currently Sat Jan 18, 2025 7:43 am
