Damp Garage
aeyres
Damp Garage
by aeyres » Wed Aug 19, 2009 4:53 pm
I have a problem of seeping water coming into my garage around the line of my DPC along 1 wall.
I've figured this is mainly due to my neighbour having built the base slab of his garage approx. 1 foot above mine, and any water collects in the gap between the garages, fills up, and seeps into my garage. Main problem is, the gap between the garages is about 6-7 inches & is impossible to squeeze between to remove all the accumulated soil & debris (now above my DPC).
I have an idea to remove a course of brick from my garage, above the line of neighbours slab & introduce a DPC at this level, whilst at the same time lining the gully area with a plastic sheet & infilling it with concrete upto his slab level along the length of the garage wall. Essentially creating a 'higher' level DPC. Is this likely to work or will i still have seepage below the concrete infill??
Any alternative suggestions would also be appreciated as it is becoming a big problem.
by stoneyboy » Thu Aug 20, 2009 9:18 pm
aeyres,
You need to stop rainwater getting into the gap between the garages see if one of the roofs can be extended to close the gap.
It is currently Sun Nov 24, 2024 11:46 pm
