Installing a Suspended Floor
Iansb
by Iansb » Thu Aug 20, 2009 3:47 pm
I need to install a Suspended timber floor into a new extension and have a few questions.
1. Do the joists just sit on the floor plate or should they be attached in some way ?
2. Should the joists be attached to the inner cavity wall in any way ?
3. Where the joists meet the external door opening, should I attach a DPC to the end of the joists ?
by stoneyboy » Thu Aug 20, 2009 9:37 pm
Iansb,
Do the joists just sit on the floor plate or should they be attached in some way ? Skew nail.
Should the joists be attached to the inner cavity wall in any way ? If the DPC is below wall plate level the inner cavity can be used for support.
Where the joists meet the external door opening, should I attach a DPC to the end of the joists ? Leave an air gap between the end of the joists and the outer wall.
It is currently Fri Jan 10, 2025 9:09 am
