Fixings for removable panels?
JEJeffrey
by JEJeffrey » Fri Aug 21, 2009 11:26 am
I have a standard 600mm carcase with an oven in it and a microwave above. The microwave has failed, and I have replaced it with one that fits the width nicely but has a large gap above (the old one was surrounded by an easily removable trim panel). I can fill the gap with panels that I have which match the kitchen decor, but then the front of the whole unit will be completely flush - fine until something goes wrong and I need access! Is there a fitting technique I can use which makes the panel reasonably secure but lets me pull it off forwards when necessary? It seems that a standard springy tool clip does the job I have in mind, but might not be firm enough.
by stoneyboy » Mon Aug 24, 2009 8:58 pm
JEJeffrey,
Buy a pair of the clips used to hold the front panel in place on a loo vanity unit.
It is currently Mon Dec 23, 2024 1:58 am
