Cutting tap holes in a bath
bkemp
by bkemp » Fri Mar 02, 2007 10:24 pm
What is the best way to cut tap-holes in an acrylic bath:?:
Mike P.
by Mike P. » Sat Mar 03, 2007 9:06 am
I did this in the latter part of last year. I used the appropriate sized cutter from a plumber's specialist kit of hole saws that I bought locally. It produced a clean hole. You will also see these kits advertised on the internet. A set of seven will cost you around £25.
thedoctor
by thedoctor » Sat Mar 03, 2007 4:40 pm
If you go to the Diydoctor projects page on Bathroon suite installation you can find a 6 piece plumbers holesaw kit there.
bkemp
Thanks for your help
by bkemp » Mon Mar 05, 2007 6:34 pm
Thanks Mike and 'theDoctor' for your help. :)
thedoctor
by thedoctor » Fri Mar 16, 2007 2:14 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Sat Nov 23, 2024 11:16 am
