Installing stair newel post and spindles
supermonkey2904
by supermonkey2904 » Sun Aug 23, 2009 3:05 pm
Hi guys
We are in the process of planning a spindle stair case and I need some advice if you can help?
The current stair case has a brick side to it, with bannister attached to intermittent studs placed between the bricks. Can I remove all the bricks down to floor level to just leave stair case showing? how do i go about securing newel post to concrete floor at bottom of stairs?...........
help needed
Thanks guys
by stoneyboy » Mon Aug 24, 2009 9:25 pm
supermonkey2904,
Chances are that the stringers are fixed into the wall so no you cannot remove the brick wall without checking first.
Newel post - dig a hole in the concrete and concrete it in place.
supermonkey2904
by supermonkey2904 » Tue Aug 25, 2009 10:27 am
Will check it out first.
Paul
It is currently Fri Jan 10, 2025 9:05 am
