drilling walls
quinnos
drilling walls
by quinnos » Mon Aug 24, 2009 8:57 pm
This is a basic question, just been trying to drill walls to put in fixings for curtain rails, my drill would not penetrate far enough, will an SDS drill do the job?? I know there is not a steel lintil in the way, but maybe a concrete one.
Thanks in advance.... :)
monty_trace
by monty_trace » Sat Aug 29, 2009 11:38 pm
hi sds should work , if not a steel lintel def a concrete one :)
Perry525
by Perry525 » Thu Sep 03, 2009 6:07 pm
Why not knock some of the plaster off and find out?
acsimpson
by acsimpson » Fri Sep 04, 2009 9:10 am
Could it be concrete with re-bar running through it. That way it would look like concrete but not drill like it.
feeding a small magnet into the hole such as a magnetised screwdriver tip should allow the substance blocking the drill to be tested.
Otherwise assuming that the drill is on hammer setting and a masonary bit being used it may be a blunt or low quality drill bit both of which could struggle with a dense concrete lintel.
It is currently Tue Dec 24, 2024 1:18 pm
