fitting laminate around a fireplace
magoo
by magoo » Thu Aug 27, 2009 12:13 am
im fitting laminate in my living room with a curved marble fire place in it am i best to start at the fire place end or the other end of the room
mrsboop
by mrsboop » Thu Aug 27, 2009 5:59 pm
hi,
not an expert at flooring but have laid quite a few rooms in my own house
and as you can see i too am having trouble
our fire place was square so i laid one long strip across the room infront of the fire which gave a nice finish then worked backwards into the recesses and then infront of the fire . plus because you've only just started you've got more patience for the fiddly bits.
hope this helps don't know if it's the right way but thats how i'd do it.
mr_vampy
Re: fitting laminate around a fireplace
by mr_vampy » Thu Aug 27, 2009 10:11 pm
Hi magoo.
It would be best to start with a straight wall at the other end of the room. When you reach the fireplace, are you able to lift it to put the laminate underneath? If so, that would save you messing around with the beading on the curved fireplace to cover the expansion gap.
Hope it helps
[quote="magoo"]im fitting laminate in my living room with a curved marble fire place in it am i best to start at the fire place end or the other end of the room[/quote]
It is currently Fri Nov 15, 2024 10:05 pm
