Sourcing a leak
inch high
Sourcing a leak
by inch high » Fri Aug 28, 2009 8:59 am
My better half text me yesterday to say that there was a leaking in the hall ceiling from our bathroom. When I got home, I couldnt see the leak. After messing around in the bathroom, the only thing I noticed was that when I filled the sink up, then pulled the plug, the bath plug starting "coughing" water out of it.
Could the leak and the bath coughing be connected?
by htg engineer » Fri Aug 28, 2009 8:44 pm
It could be, there seems to be a blockage and instead of water runniong away it backing up to the bath.
If there's a dodgy joint in the waste, when the water backs up it may be leaking.
The only way to find it, is to remove boxing/lift floorboards.
htg
inch high
by inch high » Wed Sep 02, 2009 2:20 pm
Thanks mate, will have a look....
It is currently Tue Nov 26, 2024 2:38 pm
