What is meant by 16mm2 wire
karl hurrell
by karl hurrell » Sun Aug 30, 2009 7:01 pm
Could somebody please explain what the electrician means when he says 16mm2 swa wire. What does this mean?
bd3cc
by bd3cc » Sun Aug 30, 2009 11:51 pm
16mm/2 steel wired armoured.
It is a large cable probably used fer running a sub main, possibly outside.
kbrownie
by kbrownie » Mon Aug 31, 2009 9:18 am
Hi Karl.
The size of the conductors within in the cable are 16mm2 CSA (Cross-Sectional Area). The larger the CSA the more current will be allowed to pass through the cable safely. SWA cable can come in number of sizes.
SWA= Steel Wired Armoured, this is what is known as a mechanical protected cable as steel braids run inside the cable between the PVC outer sheath and the cable conductors, preventing damage to the cable. Hench the term mechancical protection
This type of cable when used in a domestic install, would likely to be used in workshop areas like garages or outside cabling to garages, ponds, garden furniture etc...
Google "tlc-direct.co.uk/Products/SW16slash2.html"
Regards
KB
karl hurrell
by karl hurrell » Tue Sep 01, 2009 9:53 am
Thanks brownie
It is currently Sat Jan 18, 2025 5:18 am
