Old wiring help needed.
redstalker77
by redstalker77 » Tue Sep 01, 2009 6:51 pm
I removed the old light in my living room. I didnt really pay much attention to how it was connected. I am now left with 4 grey cables, 2 of which have a strip cut out the side showing red underneath. The four cables all have black, red and earth wires. Please can someone help me rig it back up as I can get all the down stairs lights back on except the living room. In the back room it only had 3 cables an I changed that light with no problems. These four cables have got me baffled :cry:
kbrownie
by kbrownie » Tue Sep 01, 2009 9:26 pm
You have 4 cables each with three conductors inside a red, a black and a earth.
The earths should be insulated with green and yellow sleeving.
Then terminated together at the earth terminal of light fitting or ceiling rose.
The four blacks 3 will be neutrals and one will be returning from your switch should be marked up with red tag/flag, sometimes this is has not been done and makes live harder.
If one is flagged up then connect that to the live terminal on fitting or rose nothing else should be with this.
The remaining blacks go to neutral terminals on fitting or rose.
The four reds are all connected together if it's a rose they go to the loop terminals if it's a fitting and no spare terminals for them a plastic connection block needs to be used, you may need to purchase one.
They (reds) are all connected together.
That should work.
If not may need a multimeter to identify switch wire this is one of the blacks, you can swap them about one at a time into the live terminal on fitting until it does work correctly(don't confuse the live of fitting/rose with the loop in connection of the reds)
If you have any problem understanding this reply, get back in touch, there is a diagram in project pages showing configuration for replacing a light fitting may be helpful. It's for three cables rather than four but it will give you an idea
Link https://www.diydoctor.org.uk/projects/re ... itting.htm
regards
KB
redstalker77
A big thanks to you.
by redstalker77 » Fri Sep 04, 2009 12:25 pm
Thankyou. I now have light again :P . I blew a couple of fuses trying to work out the switch live wire but everythings working now. Again thankyou very much for your assistance.
It is currently Sat Jan 18, 2025 5:15 am
