plasterboard fixing plates
LOSSATBEAR
by LOSSATBEAR » Tue Sep 01, 2009 7:26 pm
HI EVERYONE
JUST TO UPDATE YOU ALL I HAVE FOUND THE CLIPS BUT THE ONLY PROBLEM THEY ARE IN THE STATES HERE IS THE SITE AND YOU WILL SEE THE CLIP IN HERE IT IS THE FLAT TYPE.www.prest-on.com
Would it be possible if anyone can tell me where i might be able to purchase the following.
Small plate which fits over the top of the plasterboard with a lot of small holes on either side of plate, this is for the screws to go in when fixing from underneath the plasterboard. On the outside ceiling side where fixing the plate has two small bent elbows which snap of when finished this also allows the plate to be held while screwing in.
I have had these before and save alot of time fixing noggings/dwangs and are very sturdy once up.
:? :roll:
bd3cc
by bd3cc » Mon Sep 07, 2009 10:53 pm
Where did you get them before, other than that I don'treally understand what you are looking for.
LOSSATBEAR
by LOSSATBEAR » Sun Sep 20, 2009 10:29 pm
[quote="bd3cc"]Where did you get them before, other than that I don'treally understand what you are looking for.[/quote]
HI
I GOT THEM FROM A FRIEND I BELIEVE THAT THEY WERE GERMAN MANUFACTURED. GOT THEM ABOUT SIX YEARS AGO AND ARE ABSOLOUTLY FANTASTIC AND SAVE A LOT OF WORK.I DON'T EVEN HAVE ONE SPARE TO POST AN IMAGE. :cry:
kbrownie
by kbrownie » Wed Sep 23, 2009 8:57 pm
Could be a number of things styletrims, joint controls or beads try looking here:
Google "british-gypsum.com/products/plasterboard___accessories.aspx"
It is currently Sun Nov 24, 2024 4:10 am
