Fixing a plastic air vent to a window pane
minpher
by minpher » Wed Sep 02, 2009 2:39 pm
Hello I hope someone can help me. A hole was cut into a window pain so that a vent attachment from a poratable air condition could be attached. The vent was glued to the glass and left left sellotaped while it dried.
My problem is that half an hour later when I checked, the vent had eased away from the glass.
Can you kindly advise how I can rectify this problem myself? I think the glue (transparent) will come off easily but do I need to take it off before I reglue and can you recommend a glue I should use?
Thank you in advance
Michelle
aeyres
by aeyres » Fri Sep 04, 2009 5:39 pm
Use a product called 'Stixall' (available from independent hardware stockists). It is basically a sealant & adhesive in one, but is ideal for use on glass. (looks like a tube of silicone)
Scrape off all old glue, as this clearly is no good. Make sure area is dry & place an even amount all round vent. Stick on plastic vent, wipe off excess. Again you may need to hold the vent for compression, but product gives a fairly strong hold straight away.
Should work much better
minpher
Air vent to window
by minpher » Mon Sep 07, 2009 4:14 pm
Thank you so much for your help and advice.
Regards
Michelle
It is currently Sun Nov 24, 2024 11:24 pm
