We are having major reconstruction work done in our 6 year old 3 bed Bungalow as part of a insurance claim which they have paid up to us.
We had an electrician come round to quote and bring up to regulations of our wiring, lighting etc. who is contracted to the builder. He came round the day of the start of the work to Isolate part of the supply in the Bungalow he remove 2 electric showers and 1 switch and 1 socket plates. I had to remove a Socket plate which he missed so they can take a wall down. £186.00 quote When he left I checked the Consumer Unit, to Isolate part of the bungalow, he just switched the mcb’s to off none of the MCB’s was removed, no notice was put on the C.U. etc. Should this have been done?
Also 4 points I brought to his attention.
Down lights in the bathroom and on suite, which are standard 12v down lights one directly above the showers they have no moisture protection or to stop moisture ingress into the loft. Should these be moisture protected down lights? He said 12v will be fine.
The extractor fan is over the toilet and is close to the window. Should this be closer or over the shower? Which is 8 feet away.
We have only 1 mains smoke alarm, 18 feet distance away from the kitchen door and is sited between our bedroom door and front door. I said the smoke and heat detectors need to be on their own circuit. I said it should be on its own rcb or mcb plus do we need additional smoke sensors etc. he said it will be ok on the lighting circuit, plus he never quoted for extra sensors.
I wanted my fridge freezer on its own circuit, speaks for its own. He said it’s not part of Regs.
He as quoted for a new consumer unit.
