Can i run two bed side lamps off one plug??
6 posts   •   Page 1 of 1
Gaz118
by Gaz118 » Fri Sep 04, 2009 4:08 pm
Might be a simple one but is it feasible to run two lamps off one plug and still keep the switches for both??
kbrownie
by kbrownie » Fri Sep 04, 2009 5:21 pm
Explain, not sure what you mean. I hope your not intending to wire two flexes in to on plug top?
Gaz118
2 lights one plug
by Gaz118 » Wed Sep 09, 2009 3:40 pm
sorry about the delay, she has me on many other jobs!
with the lamps. . . we've two bed side lamps, only small, each with a switch half way down the flex as you'd expect.
My question is, can i wire them to a terminal box and run the pair off one plug?
by sparx » Wed Sep 09, 2009 7:49 pm
yes but use a proper enclosed connector not just a connector strip (no not even if you tape over it!).
Plenty on the market, sold for under cabinet lighting ect. some plug together, if using this type ensure 'plug' half goes to lamps 'socket' half to mains so if unplugged no live pins!!
regards Sparx
Gaz118
by Gaz118 » Thu Sep 10, 2009 8:31 am
many thanks
dns
by dns » Thu Sep 10, 2009 3:10 pm
Have you considered just buying a 4-way extension?!
About £1.50 in Tesco and a lot less hassle!
It is currently Fri Nov 22, 2024 7:26 pm
