Mortar Mix for gap between vertical wall and flat roof
TopSlice
by TopSlice » Mon Sep 07, 2009 5:51 pm
Hi guys
what mortar mix (if mortar is the right material to use) do I need for a leaking flat roof.
I have a patio door off a first floor bedroom going onto a flat roof. I believe there is a leak under the door - what mix (cement / sand ) do I need for the mortar to replace / cover existing material so as to stop the water getting through to the lounge below.
TopSlice
It is currently Mon Dec 02, 2024 3:00 pm
