immersion heater timer
samwise
by samwise » Mon Sep 14, 2009 10:46 am
Is it ok for someone who isn't qualified to fit a timer to an immersion heater.
I have read some information from the department for communities and local government which states
You do not need to tell your local authority’s Building Control Department about:
● repairs, replacements and maintenance work; or
● extra power points or lighting points or other alterations to existing circuits (except in a kitchen or bathroom, or outdoors).
Thank you in advance
[/b]
kbrownie
by kbrownie » Mon Sep 14, 2009 3:02 pm
Are you replacing like for like?
If so, you should be okay.
The regulations you mention are part P of the building regulations.
If you go to projects pages and search for part p it will explain what you can and can't do (notifiable or non-notifiable)
There may be a case of a minor works cert being needed though!
KB
samwise
by samwise » Tue Sep 15, 2009 9:06 am
It would be a new installation. I have spent a long time reading through part p and I find it very confusing, it seems to be open to interpretation a lot of the time.
I appreciate your time in answering my question though, thank you.
kbrownie
by kbrownie » Tue Sep 15, 2009 12:49 pm
New installation are notifiable.
A New installation some example below
Rewire
Installing new CU
Installing new circuit from the CU
Installing new protective devices on circuits at CU.
Most work done in special location (bath/shower rooms, saunas, garden area, outside locations etc...)
and kitchens will also need to be notified.
This can be done by you or someone you employ to do the work but must be done. A self cert electrician will do this for you via his scheme provider.
A lot of work involved in DIYing notifiable work and a fee is payable to building controls.
If you intend to add on to or extend an existing circuit providing not in a special location or kitchen.
a minor works cert will be needed but this is not notifiable but again minor works certs are not that easy for a DIYer.
KB
samwise
by samwise » Fri Sep 18, 2009 2:16 pm
Thank you for your time and advice kbrownie, much appreciated
It is currently Sat Jan 18, 2025 3:51 am
