Noisy water pipes from toilet cistern
john9159
by john9159 » Tue Sep 15, 2009 11:23 am
Set-up: downsatirs modern loo; mains fed; concealed pipework behind tiled wall.
A neighbour recently had a guy in to change the washer on the inlet valve although it may have been the diaphragm (not sure which as neighbour a bit vague) and now the noise made in the pipeworrk going from the cistern to that below the floor is very loud, like an that of an elephant is the best I can give.
Everything works as well as would be expected except for the noise.
No loose fittings within the cistern so I suppose it isn't water hammer.
Suggestions please.
fattiereturns
by fattiereturns » Fri Sep 18, 2009 5:55 pm
Hello mate, I know the elephant noise you're talking about. It's most probably the inlet valve, but the best way to check it to open and close the valve as the noise is occuring. You should find that each 1/4 turn changes the noise. New valve required buddy!
:shock:
janjenny83
by janjenny83 » Thu Sep 16, 2010 4:53 pm
Yes, that is probably the inlet valve. It happened to me already and I’ve just replace the valve and it worked. To make sure you should check the valve first if it is already damaged.
It is currently Fri Jan 10, 2025 1:05 pm
