float and set
rambo77
float and set
by rambo77 » Fri Sep 18, 2009 2:25 pm
what is float and set
is this undercoat plaster then skimon top
what is the correct way to apply undercoat ie bonding or hardwall to breezeblock to make sure it is level and even across the wall
any advice would be great
cheers
kbrownie
by kbrownie » Wed Sep 23, 2009 8:46 pm
Float and Set, is the method used for applying a background plaster onto bricks or stone.
Best way to apply backing plaster is to lath wall out vertically, in to equal areas then apply browning/bonding darby it level, leave to go off, then remove timbers and fill in the gaps.
KB
rambo77
float n set
by rambo77 » Thu Sep 24, 2009 3:41 pm
cheers what size timber would i use?
cheers
kbrownie
by kbrownie » Thu Sep 24, 2009 10:06 pm
slaters lath will do the trick.
chris_on_tour2002
by chris_on_tour2002 » Tue Sep 29, 2009 10:51 am
if you can get away with just using lath in vertical the corners then i usually just use thin strips of 9mm plasterboard adhered to the wall with a continuous bead of bonding behind. easy to level and set plumb, easy to rule off and has the advantage that they do not need to be removed afterwards.
It is currently Fri Nov 22, 2024 2:09 am
