upvc front door lock
normandmal
by normandmal » Fri Sep 18, 2009 6:21 pm
I need to change the barrel in the lock but can't get the key fully into the barrel its almost there but stops about 1.5 mm short so can't turn the lock and remove the barrel (hence the need to change it) any ideas please
Dan the man
by Dan the man » Sat Sep 19, 2009 8:21 pm
Try squirting some WD40 into the key chamber, sometimes its just muck inside that cloggs it up, you may not have to change the barrel too.
normandmal
by normandmal » Sun Sep 20, 2009 12:15 am
Thanks fr the advice,but stiil can't get the key all the way in
PNC
by PNC » Sat Oct 03, 2009 9:34 pm
Will it not go in fully on either side?
normandmal
by normandmal » Sun Oct 04, 2009 5:03 pm
No key will not go in all the way from both sides
It is currently Fri Nov 22, 2024 1:16 pm
