Monobloc Flexible Tap Hose.
benbo
by benbo » Sat Sep 19, 2009 11:27 am
I have a Monobloc Tap and hose's to fit.
The female end of the hose contains a rubber washer and I think it would be damaged and leak if I screwed it straight on to a compression fitting.
Do I need some other type of adaptor to protect the rubber seal such as a copper washer and 15mm olive for example?
Thanks!!!
plumbbob
by plumbbob » Sun Sep 20, 2009 12:05 am
You should by rights use something like
Google "screwfix.com/prods/74541/Plumbing/Compression-Fittings/Conex-Male-Coupler-302-15mm-x-DZR"
and fix the tap tail to the 1/2" threaded end as it is flat and won't damage the washer.
It is currently Thu Jan 09, 2025 10:56 am
