Cold Water Problem
andrewross
Cold Water Problem
by andrewross » Mon Sep 21, 2009 8:11 pm
Hi, I have just changed all the taps in my bathroom, the basin ones and the two free standing taps on the bath for a mixer style with a shower head.
Before the tap replacement - I turned off the water supply (downstairs stop valve) and the tap down stairs went off, I then went into the loft and turned off three valves (two from the cold water storage tank and 1 feeding another smaller - header ? tank). Both taps downstairs now don't flow, hot in the bathroom doesn't but the cold upstairs took ages to drain the cold water tank - which drained and didn't refill.
After the tap replacement, I turned on all 4 valves. Downstairs hot and cold are running fine. Upstairs hot is running fine, cold at the start was non-existent. I left the cold water storage tank to refill, which it did, now the cold water tap runs quickly for a second, then really slowly until it almost stops. If I turn the cold water tap on, the toilet cistern stops filling, when I turn it off it starts again - very slowly. The bath mixer cold does the same, quick, slow, trickle, stop. How can I fix this and what do you think had happened?
Thank you for all your help.
by htg engineer » Tue Sep 22, 2009 9:30 pm
Renew the ball vave in the cold water storage tank (this probably supplies the cold water to all upstairs) it's not filling the tank quick enough.
htg
It is currently Sat Feb 01, 2025 12:54 am
