Rad Problem Cracked 'In' Pipe
CraigL
by CraigL » Thu Sep 24, 2009 10:23 am
As you can tell from the title, not a plumber...!
I can bleed rads, bout as far as my knowledge goes. Stripped a wall behind my rad in living room, took rad off, bled it and reattached. My inlet pipe to the rad, coming in from the left of the rad, is now leaking from the elbow joint. How can I can stop the leak? I've got a plumber friend coming Sat, but could do with stopping the leak before then
Thanks in advance
It is currently Fri Jan 17, 2025 1:36 pm
