Laying pipe from washing machine to drain
rabbit
by rabbit » Thu Sep 24, 2009 11:55 am
Hello,
An external broom cupboard attached to the back kitchen seems ideal for a washing machine and drier. It would need a waste pipe leading to the nearby drain in the rear garden BUT I don't want to dig up concrete.
Is it possible to put a waste pipe through the wall of the broom cupboard (complete with S bend?) and lay it across a short piece of concrete (approx. 4-5 ft) into the outside drain.
The current drain cover is broken and needs replacing. I thought I could put a riser (is this is correct name?), feed the pipe through somehow and top off with a new drain cover.
To hide the short piece of pipe I thought of putting down gravel and then hiding it all with tubs of flowers.
Would this work?
Thank you.
R
plumbbob
by plumbbob » Fri Sep 25, 2009 12:00 am
I can't quite visualise exactly how you mean to lay the pipe, but in principle it should be fine.
Just a few pointers. Put the washing machine trap in the broom cupboard. Make sure the pipe always has a small fall so water will not collect in the pipe. Finally, make sure the intended drain is a foul sewer and not simply a drain for rain water.
rabbit
by rabbit » Fri Sep 25, 2009 9:24 am
Thank you for your advice. Yes, the drain is for sewage. Will go ahead with plan. Thanks again. R
Update 28 Sep 09
Further to that advice. A friend suggested putting in a small heating unit (e.g. a tubular heater like a Dimplex or similar) to prevent the washing machine and drier from damaage (?) resulting from any freezing weather. Is this necessary?
Thank you. R
27col
by 27col » Mon Sep 28, 2009 7:35 pm
If it is an unheated external room, then it would be wise to install a small heater. This should be of a type that incorporates a frost stat. It is not sufficient just to lag the water pipes. If the room is unheated for long enough during a spell of below zero weather then the water pipe will eventually freeze. A small heater with a frost stat will maintain the room just above freezing, but will only operate if there is a real need for it. It would be a good idea also to make sure the room is as draught proof as possible.
rabbit
by rabbit » Tue Sep 29, 2009 10:37 am
Thank you for this advice. :D
R
It is currently Thu Jan 02, 2025 6:46 pm
