Fibreboard ???
6 posts   •   Page 1 of 1
angela
Fibreboard ???
by angela » Sun Sep 27, 2009 2:10 pm
HELP! Have just started renovating 1968 chalet bungalow and although was supposed to have been completely roof insulated found that no insulation behind any pitch ceilings ie most of upstairs, so got to remove board which is not plasterboard but something like half inch thick cardboard-- vague idea may be fireboard? Anyway if can get away without removing bits outwith insulation job but replacing stuff I do have to remove with conventional plasterboard, can I skim plaster over the lot including fibreboard or wharever it is? Anyone know as have had conflicting advice so far!
by stoneyboy » Sun Sep 27, 2009 10:26 pm
angela,
If you can do the insulating without removing the fibreboard then fit plasterboard ontop of the fibreboard. Do not try plastering fibreboard direct.
angela
Fibreboard
by angela » Tue Sep 29, 2009 10:50 am
Thanks for your reply is it fibreboard and any advice on how thick plasterboard should I use for walls and ceilings
by stoneyboy » Mon Oct 05, 2009 9:24 pm
angela,
Building regulations now require you use 12.5mm thick board but if you can find it you could use 9.5mm.
kbrownie
by kbrownie » Mon Oct 05, 2009 9:50 pm
12.5mm for ceilings, 9.5mm for walls normally. but 12.5mm is now being used for most applications.
KB
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 05, 2010 8:57 pm
Find trusted, insured and vetted tradesman local to your area. Visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Nov 22, 2024 5:05 pm
