4 Halogen Lamps on Dimmer
Chris12
by Chris12 » Thu Oct 01, 2009 10:07 am
I have 4 halogen lamps rated at 240v 50w and wanted to put them on one dimmer switch, I noticed that the dimmer switch is rated at 400w but only 200w for halogen light, so some quick maths tell me I have 200w so is it ok to use the dimmer switch being that it is at the maximum limit?
Dusklights.co.uk
As long as you dont exceed
by Dusklights.co.uk » Thu Oct 01, 2009 5:06 pm
The fact that you are hitting the limit and not going over it is not a problem. All devices include a tolerance its not like you are going over by a few watts. Don't panic just you are on the safe limit
by sparx » Thu Oct 01, 2009 9:23 pm
hi, yes of course, its a limit like any other, if speed limit says 40 mph thats the max not 39.5 same thing,
regards Sparx
Chris12
by Chris12 » Fri Oct 02, 2009 1:17 pm
Thanks for the info, much appreciated.
It is currently Fri Nov 22, 2024 1:29 pm
