wiring a ceiling rose - 3 black cables from ceiling?!
Jungle Jen
by Jungle Jen » Thu Oct 01, 2009 5:13 pm
Hello
I would like some advice on wiring a ceiling rose, I have checked the projects pages but... I only have 3 all black cables descending from the ceiling. How can I find out which is which?
steve the plumber
by steve the plumber » Fri Oct 02, 2009 1:38 pm
This is what you need:
https://www.diydoctor.org.uk/projects/re ... itting.htm
If the switch is not clearly labelled then trial and error. If the light is upstairs, climb up in the loft and trace the switch wire.
by sparx » Fri Oct 02, 2009 8:16 pm
Hi, this is when you need to be a 'Sherlock Holmes'
probably the other circuit cables, (3 Reds & 3 earths) are tucked up in ceiling.
what you have is 2 neutrals which go to blue flex end of rose + 1 switched live which would have been on its own & should go to brown flex end of rose, this should have red sleeve/tape on it.
It may be possible by examination to see 2 that have been twisted together or 1 that was on its own, if not and as has been suggested visual check not possible then continuity test from switch to each in turn will show switch line,
Always work on dead circuit and if unsure please get help, it should take no more than 1/2 hr for leckie to fix.
regards Sparx
It is currently Wed Jan 29, 2025 7:03 pm
