Hi i am hoping someone can help me understand what i need to do with regards to converting my attached garage into a dining room.
The gargage used to be a sales office for the surrounding housing estate back in 1997 but was turned back into a garage when the new owners moved in. so it has a ceiling and plenty of electric wall sockets and even french doors at the rear. they also had a doorway back into the living room which is bricked up. and it is plastered throughout.
my questions are:
1. i am going to still use the front of the garage as a garage (about 1.5m) and then erect a studd wall to split it into 2. so it will still look like a garage from the front. will a stud wall be sufficient? and what materials should i use to erect this wall?
2. the wall that seperates my garage from my neighbours is single breeze block wall, how do i insulate this wall? can i just batten the wall and insulate between the battens and plaster board and plaster over?
3. i imagine i wont need to insulate the wall that joins the house?
4. The floor is the standard concrete floor- what would i need to do to raise it to the same as the living room and insule it?
to me it seems like quite a simple job ;-) but of course i want to keep to building regs as its the law and they will check up on the work i do anyway -dont they?
any help or advice u guys can offer will be great
cheers
Neil
