Vapour barrier plasterboard to eliminate mould
daztc
by daztc » Thu Oct 01, 2009 9:20 pm
We have bad molud problem probably caused through being north wall and cold room, It has been suggested by fixing foil backed palsterbosrd will solve the problem. is the boards appixed by adesive or to battens?
Dan the man
by Dan the man » Fri Oct 02, 2009 5:00 pm
You can not use dry lining adhesive to fix foil back boards, you can only screw them to battens.
It is currently Wed Jan 15, 2025 10:56 am
