Light switch
beerbreak
Light switch
by beerbreak » Sun Oct 04, 2009 10:59 am
Hi i have changed a ceiling rose and light switch which seems to work fine but leaves a fishy smell when left on,ihave rechecked the wiring and all looks fine .ANY IDEA's.
cheers
kbrownie
by kbrownie » Sun Oct 04, 2009 7:11 pm
Sounds Fishy!
excuse the pun, something is overheating and that's not good.
Could start a fire.
Is the fuse rating correct for the cable are all terminals tight and no bare conductors outside the terminal points.
If the smell continues stop using the light and get an electrician in.
Check this link out:
https://www.diydoctor.org.uk/projects/re ... itting.htm
KB
Dazzman
Fishy Smell
by Dazzman » Mon Oct 05, 2009 1:08 pm
I had the same problem it was the light bulb touching the bottom of the fitting that holds the shade in place, the bit that screws onto the ceiling rose, it had started to turn brown and made the place smell like a wet fish shop.
Hope this helps?
It is currently Sun Nov 24, 2024 2:32 am
