outside taps
alanpease
outside taps
by alanpease » Thu May 31, 2007 11:50 am
I have an outside tap for the garden hose but when I turn it on water seems to come back out of the connection. When the water is not turned onto the tap there is no leak so I imagine the washer on the tap is OK.
bazza
outside tap
by bazza » Thu May 31, 2007 10:00 pm
hi alanpease turn the tap off via the isolating valve undo the connection and add sum ptfe tape that will solve your problem bazza
alanpease
by alanpease » Fri Jun 01, 2007 10:23 am
Thanks bazza I will give it a try.
konane
outside tap
by konane » Fri Jun 01, 2007 10:53 pm
when I turn on my tap with my hose water leaks from the handle and the connection from the tap to the hose. Right when I turn off the water it bursts out from the connection. Should I replace the tap or just put some tap on the threads?
It is currently Mon Dec 23, 2024 4:36 am
