Dot n dab or plaster concrete ceiling?
firstinterior
by firstinterior » Fri Oct 09, 2009 6:01 pm
I have about 1000M2 of concrete slab ceiling to finish. I don't have the option of framework because of the clearance needed. Does anybody know the best method (gyp bond-it, float and skim) or (dot n dab and skim)? I'm also struggling for a labour rate to charge as it's not a very nice task.
Thanks for your help.
ricky68
Re: Dot n dab or plaster concrete ceiling?
by ricky68 » Sun Oct 11, 2009 10:34 pm
batten it and p/board it,gyp-liner and p/board it.you cant dot & dab it.you can float & set it.if it is in the south i could give you a rate for it.
It is currently Sun Nov 24, 2024 3:42 am
