compressor
Newbee
compressor
by Newbee » Mon Oct 12, 2009 2:16 pm
Hi there, I've got a static caravan which I'm about to drain down for the winter, I usualy just open the taps and the drain plug and crack a joint open in a problem area but this year our site was fully serviced and I insulated all the pipes so can't get at the joint to open it.
Two guys around me are also needing a compressor, does anyone think the one below will be suitable? or does anyone have any suggestions.
Thanks in advance
http://www.maplin.co.uk/Module.aspx?ModuleNo=225095
jolaidler
Re: compressor
by jolaidler » Sat Nov 21, 2009 12:48 pm
we are in a similar situation - did your compressor work. Any info would be appreciated.
thanks
jolaidler
Re: compressor
by jolaidler » Sat Nov 21, 2009 7:09 pm
thanks[/quote]
It is currently Fri Nov 22, 2024 6:16 am
