SIZE OR NOT TO SIZE that is the question.
NORMAN
by NORMAN » Sat Mar 03, 2007 11:36 am
Condensation problem on the bedroom wall has led me to lining the wall with a double layer of polystyrene insulation approx now 1/4" thick. This has cured the cond'i problem, but now the tester is do I size the polystyrene with a stronger mix? wallpaper while the size is still moist?or is there another product that will seal the polystyrene layers? I can't afford to do a trial and error as my wallpaper is extremely limited.
No jokes about hot & steamy bedroom antics thanks, I've already done them. :lol:
Dave
by Dave » Mon Mar 05, 2007 8:15 am
This has not solved your condensation problem just moved it.
Air movement is the answer.
you want ten millimeter gap under the doors
thedoctor
by thedoctor » Mon Mar 05, 2007 8:50 am
See the project on the website called condensation Norman.
NORMAN
by NORMAN » Wed Mar 07, 2007 2:30 pm
Indeed Dave, good air circ' & ventillation was my prime concern. Thus I rectified first which left a small alcove type area in one corner of the room, which seemed to suffer from a condensation problem brought on by it being a outer wall and not of brick but tiled roofing /minimal insulation/plasterboard. Fitted cupboards on the adjacent wall have added extra circulation problems (previous owners).
UPDATE: I've gone ahead with a stronger than normal size mix, left to dry , papered over and left to dry at room temp for 2 days . So far I CAN detect hairline splits appearing on the seams , so its looking like another attempt later in the year.
thedoctor
by thedoctor » Fri Mar 16, 2007 12:56 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Thu Dec 26, 2024 9:13 pm
