Second loop on ring main
MagicalTrevor
by MagicalTrevor » Thu May 31, 2007 8:14 pm
I've recently bought a house & have been considering getting the ring main extended to add a couple more sockets in the living room. I would probably get a electrician in to do this but wanted to get an idea of what the job would entail before hand.
On inspection of the current ring main I discovered that additional sockets have already been added by means of an additional loop on the ring main i.e. If the original loop is 1-2-3-4-5-6, there is a second loop running between 3 & 4 , 3-A-B-4.
Does anyone know if this an issue and if so can it be resolved by just removing the connection between 3 & 4?
Thanks.
by sparx » Fri Jun 01, 2007 4:35 pm
HI
YES & YES, well spotted M T. with double loop ie fig 8 would throw up odd test results if full readings taken and might raise ? on later periodic insp. eg for a sale etc, best to sort it now!
regards SPARX
MagicalTrevor
by MagicalTrevor » Fri Jun 01, 2007 4:57 pm
Thanks Sparx, I'll get on and sort that...
It is currently Mon Jan 06, 2025 2:58 am
