Installing an electric radiator
thickiebrickie
by thickiebrickie » Thu Oct 15, 2009 11:34 pm
How do I install an electric Myson Finesse radiator to the mains electric. The instructions say that it has to be connected to the fixed wiring of the house via 5 amp max cable outlet. It has come with a 2 point plug attached to it, why cant I fix a standard plug to it and plug it in to a normal socket.
kbrownie
by kbrownie » Fri Oct 16, 2009 3:29 pm
2 pin plug?
It should be hardwired using either a Switched Fused Contection or a Fused Connection Unit(FCU). Rated at 5A.
The flex from the rad will be terminated load side of FCU and the spur feed will be terminated supply side of FCU.
This will mean taking a spur from a socket-outlet on the ring final or radial socket circuit or breaking in to the circuit underneath the floorboards but all joints unless crimped or soldered must be accessible so sockets usually a prefered choice.
KB
It is currently Thu Jan 30, 2025 9:02 pm
