Lighting help please
jayb1986
by jayb1986 » Fri Oct 16, 2009 8:24 pm
Hello
Am in the process of installing a new ceiling light and have some questions to ask as i'm having some troubles.
When I took the old fitting down i found that there were 2 t&e cables coming down with one marked with red tape (switch wire I assume). Rest of the house has 3 t&e's except this one light- this light is on a loop with the rest of the downstairs lights.
Obv I have 2 earth, 2 red and 2 black- The 2 reds where connected together in a seperate terminal block with nothing coming off them. The black wire was connected to the N terminal on the light unit, the earths to the earth and the black wire ( with red tape) was connected to the L terminal.
The light still doesn't work, what have/am I doing wrong? I'd appreciate any help because at present the lights downstairs obviously dont work.
many thanks
note: the terminal block connected to the light fitting has 1 blue(n) , 1 brown(l) and 1 earth(g&y)
chriscba
by chriscba » Fri Oct 16, 2009 9:03 pm
Youve got 2 t&e's because it's proberly end of the circuit. i.e. mains in to the fitting & switch return.
You might have loose connection or broken wire somewhere, have you got a multimeter to test for voltage.
steve the plumber
by steve the plumber » Fri Oct 16, 2009 10:21 pm
by sparx » Fri Oct 16, 2009 11:51 pm
what you have done is correct.
you say the rest of the lights don't work?
As there are only 2 cables and the others all have 3 then this must be the last one on the circuit & all others should work even if you have made a mistake with this one,
are you sure you haven't ;
a] blown a fuse.
b] missed a cable
not many other options
It is currently Sat Jan 18, 2025 1:03 am
