Buzzing consumer unit
Lawrence
by Lawrence » Sun Oct 18, 2009 10:48 am
I have recently fitted some dimmable low energy bulbs and changed the dimmer switch (link below) which I was advised was designed to be used with low energy dimmable bulbs
However, when I now have the lights on (dimmed or on full power) I get a buzzing on the breaker at the consumer unit.
Does anyone know why I get this buzzing and how I can stop it
thanks
Google "theinternetelectricalstore.com/hq7w-1-gang-1or2-way-0-120-watt-push-onoff-standard-dimmer-switch-white-plastic-white-knob-702-p.asp"
steve the plumber
by steve the plumber » Mon Oct 19, 2009 1:52 pm
How many bulbs are operated by the switch and what wattage are they?
Lawrence
by Lawrence » Tue Oct 20, 2009 7:27 am
there are 6 x 9W bulbs
the circuit is a 2 way with only one dimmer switch
thanks
steve the plumber
by steve the plumber » Tue Oct 20, 2009 5:31 pm
It's normal for the dimmer switch to be buzzing but not the on the MCB.
I wouldn't use a dimmer on low energy lighting. Fit a normal switch and see if the buzzing stops.
It is currently Thu Nov 21, 2024 11:41 pm
