One Cold Radiator
8 posts   •   Page 1 of 1
motoloco
One Cold Radiator
by motoloco » Tue Oct 20, 2009 10:28 am
My heating system works fine, except for one upstairs rad which stays completely cold. The feed pipes to and from it are also cold. I have bled it and there is no air and the pin on the TRV moves freely. I've tried turning all the other rads off to send all of the hot water to the cold rad, but that hasn't made any difference.
I've recently moved into the house and I'd guess the heating system is 15 or so years old. The system comprises 2 rads downstairs and 3 rads plus a heated towel rail upstairs. Any ideas?
steve the plumber
by steve the plumber » Tue Oct 20, 2009 5:22 pm
Silly question but is it actually connected?
motoloco
by motoloco » Tue Oct 27, 2009 9:23 am
I think so! The room has a laminate flor, so it's not easy to get the boards up
MrsDavey the plumber
by MrsDavey the plumber » Tue Oct 27, 2009 8:46 pm
Hi there. Is the locksheild turned on?
by MrsDavey the plumber » Tue Oct 27, 2009 9:03 pm
is the locksheild turned on?
motoloco
by motoloco » Wed Oct 28, 2009 6:54 pm
Yes the lock shield is open and the rad is full of (cold) water. All the other rads are the same (hot) temp, but this one is cold.
Barry Bunsen
by Barry Bunsen » Thu Oct 29, 2009 7:08 pm
You could turn off the two valves and let some water out of the bleed valve to depressure the rad. When you close the bleed valve and re open the valves you could see if it repressurises, using the bleed valve again. The point is it would answer Steves question about whether or not the rad is connected - unless you have a mega blockage.
It would also be interesting to see if you cracked the nuts under the valves whether or not water would flow, but you would have to know what you are doing (turn the boiler off, expect a mess, put the system back to the correct pressure, remove any new airlocks, maybe add some more inhibitor etc)
Good luck.
motoloco
by motoloco » Sun Nov 01, 2009 4:40 pm
Thanks Barry
I've tried what you suggested and the rad fills up again, so there doesn't appear to be a blockage. I guess it's time to call a plumber!
It is currently Mon Jan 06, 2025 4:35 am
