Replacement part for a Caradon Siphon.
Sean Walshe
by Sean Walshe » Tue Oct 20, 2009 9:00 pm
Over 10 years ago we had a Sani-plus installed with a WC, shower and sink connected. The toilet cistern has a Caradon siphon without an external over flow. Instead it has a hole in the siphon with a mechanism that covers the hole and held in place by a float pulled taught around the siphon, which if the cistern does over fill the float comes off exposing the hole. Unfortunately age has caused the plastic on the mechanism to go brittle and fail. Before replacing the Siphon does anyone know if the overflow mechanism can be replaced?
It is currently Sat Jan 04, 2025 3:13 am
