WOOD BURNER FLUE AND CHIMNEY
david.mccrossan1@btopenwo
by david.mccrossan1@btopenwo » Sat Oct 24, 2009 10:14 am
I AM FITTING A WOOD BURNER MY COTTAGE IS 200 YEARS OLD AND SEMI DETACHED THE CHIMNEY IS A JOINT CHIMNEY THE ATTACHED FIREPLACE IS BLOCKED UP WITH AN AIR BRICK, MY FIREPLACE HAS ALWAYS HAD AN OPEN FIRE AND I WANT A WOODBURNER I WILL FIT A FLUE,DOWN THROUGH THE CHIMNEY TO THE WOOD BURNER WILL THIS CAUSE A PROBLEM FOR MY NEIGHBOUR HE HAS NO OBJECTION TO ME FITTING THE BURNER.
It is currently Fri Jan 31, 2025 3:02 am
