Light switch query
Fearn
Light switch query
by Fearn » Sat Oct 24, 2009 10:50 am
Hi folks,
I am trying to change (what I believed to be) a 1 way 1 gang light switch for new after decorating a bedroom. I've done this before in other houses, which has usually been straightforward by copying the previous wiring. However, in this instance things are a bit different. As I don't understand the setup, and have no other electrical experience, I was hoping one of you good people might be able to advise me.
I've taken some photos to show the current setup:
http://img148.imageshack.us/img148/8567/p1000127.jpg
http://img198.imageshack.us/img198/815/p1000128t.jpg
And this is the light switch I bought, which I'm presuming is wrong as it only has 2 points of entry for the wires:
http://img148.imageshack.us/img148/2488/p1000131m.jpg
Any advice appreciated.
Fearn
chriscba
by chriscba » Sat Oct 24, 2009 2:27 pm
You need a 2 way, 1gang switch, then put red from 3 core to com, red from 2 core & yellow in either of the other ones, & black & blue in the other. Go to projects, theres something in there might help you
BLAKEY1963
by BLAKEY1963 » Sun Oct 25, 2009 9:16 am
FEARN ISOLATE POWER ! TURN OFF MAIN SWITCH.
copy existing positions of two way switch , on your image.
TRIM COPPER cores so NO EXPOSED terminations.
Tag up black , yellow and blue cores to identify them as live conductors.
Most important , chack integrity of earthing conductors ( green and yellow sleeved copper cores ) and reafirm sound connection in to back box of switch.
BLAKEY1963
It is currently Sat Jan 18, 2025 1:51 am
