Fixing to walls
7 posts   •   Page 1 of 1
tomo
Fixing to walls
by tomo » Sat Mar 03, 2007 1:26 pm
Can somebody please describe the best, secure mounting to hang mirrors/pictures/hanging baskets..... to Cumbrian stone walled houses? (Both out side and inside please).
sparrow
Fixing to walls
by sparrow » Thu Mar 08, 2007 7:38 am
See the fixing to masonry project on the website it explains it all.
tomo
Re: Fixing to walls
by tomo » Thu Mar 08, 2007 1:01 pm
[quote="sparrow"]See the fixing to masonry project on the website it explains it all.[/quote]
Shall do; Thanks for your direction.
thedoctor
by thedoctor » Fri Mar 16, 2007 1:48 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
tomo
Fixing to Cumbrian stone walls
by tomo » Fri Mar 16, 2007 4:23 pm
With the pictures, that was really useful. Thanks.
megan
kitchen caninets
by megan » Thu Mar 29, 2007 7:20 pm
can you help . i would like to put up new kitchen cabinets but i have loads of electric sckets what can i use to put the cabinets onto, is there a type of rail that i can use
thedoctor
by thedoctor » Tue Apr 17, 2007 6:38 am
Not sure what you are asking here Megan. What is the rail for? Are you trying to keep the units away from the wall surface so you can install them over the sockets? If this is the case and you do not want to use the sockets any more it is much easier to remove the socket front plate, terminate the wiring in a connecting block and fix a proper blanking plate to the sockets.
It is currently Wed Feb 05, 2025 12:45 pm
