low pressure problem Triton Zante shower
tosspot26
by tosspot26 » Tue Nov 03, 2009 2:56 pm
I have a Triton Zante shower and after approx 5 mins the low pressure light comes on and water shuts off, can anyone tell me if this is a valve or solinoid problem, or something else, thanks Tosspot26
rosebery
by rosebery » Tue Nov 03, 2009 10:26 pm
Electric showers should be fed with mains cold water. If you are feeding it from a tank in your roof it will not work properly. So the obvious questions are how is it plumbed and have you checked the pressure?
Otherwise check the solenoid for resistance using a multimeter. Make sure the power is OFF first though! If you get no reading replace the solenoid.
It is currently Mon Jan 06, 2025 5:54 am
