Water seeping into shed at ground level
Lancastrian
by Lancastrian » Wed Nov 04, 2009 4:43 pm
I have a shed constructed about 10 years ago of breez blocks which stands on a concrete slab.
Water is seeping in at ground level at the back ( just in one place about 3 feet in width - the rest of the back is watertight) - the breeze blocks are cemented to the concrete slab and there don't appear to be any cracks in the cement where the water is getting through.
Is there anything I can do to make a better seal in the affected area,
Perry525
by Perry525 » Thu Nov 05, 2009 6:52 pm
Look at it from a different view.
Stop the water getting in by digging out a gully to both lower the surface beside the shed and move the water away.
A simple French drain will do the trick.
It is always a good idea to have the slab at least six inches above ground level.
Lancastrian
by Lancastrian » Fri Nov 06, 2009 3:49 pm
Thanks Perry525.
I will construct a gully.
I am newish to DIY- - What is a French drain - Is it like a soak away filled with chippings?
rosebery
by rosebery » Fri Nov 06, 2009 11:54 pm
Google for it. In a way you are correct.
BTW do you think that this problem might be connected with your other thread?
Lancastrian
by Lancastrian » Thu Nov 12, 2009 8:55 am
Thanks Rosebery :)
I googled it and made a sort of French drain and the problem is sorted.
The shed is right over the other side of the garden from the entrance drive and the 2 problems are not connected.
I have been away for a few of days and havejust looked at your posting on the Stop cock question and understand what you say and will get back to you.
Thanks,
Keith
It is currently Fri Nov 15, 2024 6:53 pm
