Laminating around hearth
matthill79
by matthill79 » Thu Nov 05, 2009 2:12 pm
I'm about to start laminating the floor in the living room and plan to replace the skirting and architrave with new skirting as I don't like the look of beading to hide the gaps.
My problem is that I have a stone hearth that is set on concrete and I want to know how to lay the laminate around it to make it look its best. Should/can I butt the laminate to the hearth? I've also seen some cork strips which may do the job but still don't look great.
Can anyone help please?
Matt
rosebery
by rosebery » Thu Nov 05, 2009 6:40 pm
Fairly tight to the hearth but still leave a small gap compared with the edges which will be under your new skirtings. The laminate suppliers will provide you with a "special" filler coloured to match the laminate to fill the gap. Bit like silicone sealant and you apply it with a cartridge gun.
matthill79
by matthill79 » Fri Nov 06, 2009 9:54 am
Thanks. I've ordered my laminate from B&Q, can you reccomend a filler or brand?
rosebery
by rosebery » Sat Nov 07, 2009 12:12 am
B&Q sell it. Ask the gentleman in there which one he recommends for the floor you have purchased.
It is currently Mon Nov 25, 2024 10:42 am
