No Water From Hot Tap - Changed Washer - Still No Water!
slapmatt
by slapmatt » Thu Nov 05, 2009 7:50 pm
The water stopped flowing from the hot tap on our bath, so I successfully changed the washer (it was mullered) and re-fitted everything.
Now the hot tap will only turn about three-quaters of a revolution and still no water comes out. If I manually turn the whole value slightly with a spanner the water flows freely - as if the tap is not opening the value enough (if that makes sense).
Please advise before the wife gets home!
It is currently Mon Jan 06, 2025 4:43 am
