over heating imersion timer switch.
mark c
by mark c » Sun Nov 08, 2009 11:36 am
have imersion tank on timer switch.
switch started to mailfunction.
on inspection i found that both live terminals connecting blocks (supply in and out) had melted.
could anyone supply a reason for this and how to avoid it happening again.
hamish72
Re: over heating imersion timer switch.
by hamish72 » Mon Nov 09, 2009 7:08 pm
[quote="mark c"]have imersion tank on timer switch.
could anyone supply a reason for this and how to avoid it happening again.[/quote]
Probably simply screws not tight enough which creates resistance and thus heat at the terminal
Or the switch not rated high enough to match the heater load
It is currently Sun Nov 24, 2024 12:51 pm
