Removing paint 'overlap' from varnished wood and stone
bundy
by bundy » Fri Jun 01, 2007 3:12 pm
Following an enthusiastic decorating session, some of the matt emulsion used on the walls has 'overlapped' onto surrounding varnished woodwork, and onto an untreated stone fireplace.
Any recommendtions / suggestions for removing this without stripping the varnish or staining the stone?
thedoctor
by thedoctor » Mon Jun 04, 2007 10:12 am
See our paint stripping project which (liquid stripper) will remove the paint safely from the stone but for the varnished wood we suggest rubbing with warm water and a cloth. If its only emulsion it should come off without damageing the varnish. If not you will have to use the stripper and revarnish.
bundy
by bundy » Mon Jun 04, 2007 11:43 am
That's great, thank you. We'll give the paint stripper a go on the stone.
It is currently Sat Nov 23, 2024 4:52 pm
