Ceiling Joist Sizing
6 posts   •   Page 1 of 1
mapearce
by mapearce » Fri Nov 13, 2009 8:42 am
Hi.
I am putting a new independant ceiling below the existing ceiling in my living room. I live in a ground floor flat. The span is 3.8m across the room. I want to put the joists at 400 c/c. There will be no load from above as its indepandant. I am going to fix 2 sheets of plasterboard (12.5mm and 19mm) to the underside of the new joists and then skim.
Can anyone help with the sixe these joists should be?
bd3cc
by bd3cc » Mon Nov 23, 2009 10:53 pm
are they fixed to the ceiling above or suspended?
why 32mm of plasterboard. if for soundproofing dB chech and high density insulation?
Timberjack13
by Timberjack13 » Sat Dec 19, 2009 10:48 am
HI, if there is no weight on the new joists then 6 x 2 should be ample, u could prob get away with even smaller timbers, id dry line screw the 12mm plaster board to the joints...joints should idealy be inbetween 400--600 centres! and then skim over
Is it just a case of lowering the ceiling?
Perry525
by Perry525 » Mon Dec 21, 2009 6:46 pm
There are tens of thousands of homes with twelve foot wide rooms where the traditional 4 x 2 inch joists have been in place as ceilings/floors for lofts, for over a hundred years, many are loaded with many things. You can add to this the weight of people walking across the lofts as well.
claridge
new ceiling
by claridge » Thu Feb 04, 2010 9:29 pm
I would suggest a 4x2 be more than sufficient ensuring the joists are fixed mid span from the existing ceiling/flooring joists of the flat above. This fixing could be in the form of a hanger that enables the the ceiling to be much lower then 4 inches,the depth of the the new joists.
If the ceiling is completely independant obviously always span the shortest distance and consider a 6x2 but ensure the wall plate timbers (boundary ) are resin bolted to the masonary as the net weight of the ceiling as a whole with plasterboard and skim is cosiderable.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jun 28, 2010 10:02 pm
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Nov 22, 2024 2:25 am
